Limit switch wiring Does the Azteeg X5 V3 require NC or NO limit switch
Limit switch wiring
Does the Azteeg X5 V3 require NC or NO limit switch wiring?
Either will do, you can reverse it in the config
I prefer NC simply because it trigger a limit in the case of a disconnected wire rather than crashing into the switch
@Zane_Baird agreed, didn’t realize it was configurable.
I did normally open, just make sure you change the config. Mine was defaulted to NC. Potato potato. Typing that feels stupid.
