Lessons learned. After doubting my wiring, my code, my power supply, my design,
Lessons learned. After doubting my wiring, my code, my power supply, my design, and my sanity, I finally traced the intermittent issue I was having with my 2nd 64 x 64 matrix to a bad Teensy 3.2 OctoWS2811 Adaptor. So, the lesson is trust nothing and start by swapping out the easy stuff first. This could have been solved long before it was.
Excellent advice.
@Mark_Estes thank you for sharing !!
3 steps in trouble shooting… divide in half. Look left signals good, step right and repeat… :slight_smile:
@Mark_Estes oh my, sorry to hear this. Now, do you even need the OctoWS2811? Can’t you wire 16 or even 24 lines to a teensy directly without it?
