Layered Lines During Printing
Does anyone know what could be causing these lines?
It’s just an addition to a funnel. It’s printed in PLA, head is at 200 and the bed is at 50. I had the print speed at 60 and it was well stuck to the bed without any lifting.
any ideas?
Worst than the lines is the fact that there’s lots of layer adhesion problems. Just look at the loose traces when the bevel to the small diameter is.
Could be caused by layer height too large for the nozzle diameter. IIRC it typical to not go higher than 80% of the nozzle diameter. Moisture in the filament can cause lots of visual problems,
