LaserWeb Software Thoughts
I’m using 4.0.48 distributed by DarklyLabs.
Sorry if some of this is redundant and rambling.
ISSUES
BUG: version 4.0.48. When selecting Cut Outside the Laser Diameter field doesn’t show up. Behaviour is inconsistently when the cut type menu is changed. I think the fields are not updating at the time of change.
Fix the negative effect caused by dragging a file into the application window. Either stop it acting as a viewer or put in a back button.
IDEAS
Button to duplicate an individual CAM’s path-job. For example if I were to do a 45 deg hatching It stands to reason I want the same settings for a 135 deg hatching. Duplicating makes sense. Also this would be handy for sequencing a final cutout.
Move Gcode section into it’s own sidebar tab/button between cam and jog tab/buttons.
Option for alert sound for errors and completion of job and gcode generation etc. sounded through the PC audio output.
When “Hide Docs” is clicked it should really make better use of the space. Reduce it to a single clean button to expand again.
Have file or file part deselect when clicking in white space bellow the list of files and file parts.
An operation to thicken a line to be used as a surface drawing.
Add a dot where the beam tip is located within the transparent blue cone.
A permanently visible dynamic connection button that updates to reflect status and function. Toggle between connect and disconnect.
Move the terminal either to it’s own tab. Or have it fixed at the bottom of the menu. But collapsible to a 1 or 2 lines. Perhaps View settings, Simulator and Terminal could be in tabs. The issue for me is i use a small VGA display and the terminal is almost offscreen.
More Clearly define the stages in the CAM’s workspace. For the uninitiated it’s extremely hard to see the intension of it’s layout no matter how logical it is.
Have a default first entry option for setting values that will be used by default by all subsequent path-jobs unless overridden there. For example the “Start Height” is likely the same value throughout the one workspace. Opposed to the more portable and project independent settings default.
Perhaps a preset CAM’s workspace, path-jobs menu available across all workspaces.
Export CAM’s workspace, path-job data as a clear clean text file with the option to import as well. Perhaps this would work in conjunction with the previous idea.
A Button to Zoom and Crop viewable area to show all of the loaded data as part of display settings.
Not have the viewable area hidden behind the menu.
New Workspace Button.
Option to turn off or completely hide the tool graphical area of the CAM’s workspace.
Have workspace save and gcode save buttons save to preset file names and locations at a click. Unless one has not been set yet.
Option, where multiple passes are set, the value, 1, 2, 3, etc. can be cut into a specified area as each pass is started.
