So I have been able to connect to the pi install of laserweb with little issues (small connect on reset issue, but fixed).
Now I am trying to get the USB camera that is directly connected to the PI to be seen. Not sure what address i need to enter in the camera section… it looks to only prefill the local machine camera, not the one on the PI.
There is no video streaming implemented into lw.comm-server. You need a server app on the raspi that streams the camera via network streaming protocol (like RTSP). I think VLC should work for that. Then you can use the camera url provided by this server to connect from LaserWeb.
It’s not enough to enter the ip, you need a whole streaming url like:
rtsp://username:password@192.168.1.30:554/h264Preview_01_main
This link is defined by the streaming server on the pi.
@cprezzi The link you sent in the thread, did not setup username/password link… it only gives ip:8081… and that works perfectly in all the browsers… I did not see a step in the article on how to setup a username/password for the webcam feed.
Any other ideas on how to make LaserWeb see the PI Camera feed?
@cprezzi I know that the front end isn’t your specialty; do you happen to know whether MJPEG streams work? If so, the http://raspberypi:8081 (or use the IP address, like http://192.168.0.10:8081 substituting whatever the pi’s actual IP address is) ought to work. It looks like there is other software that can stream RTSP from the pi if that’s a requirement, but it didn’t sound like it is?
@Stady234 I did see that there are tutorials on using the rpi to stream RTSP but I don’t have any experience with any of them, I just saw that they exist.
Unfortunately I also don’t have any experience with video streaming to the LW frontend and don’t remember which protocolls are supported (like rtsp, rtmp, http). The link I posted was the first I found for setting up video streaming on the raspi, but it is not related to LW. The username & password is optional in a streaming url and so is the endpoint (the part after the IP:Port). They are dependent on the configuration of the streraming server. The url example I have posted is from a surveillance cam.
Hint: The streaming url is not the same like the url of the streaming server website. If you call the url with a web browser and get a page with an embedded video player, then it is the url that the videoplayer uses that we need.
I also couldn’t find any documentation on the LW video feature, but I remember that @Jorge_Robles has implemented that part. Eventually he can help.
