LaserWeb generated test files
Hi, old dog here trying to learn new laser tricks.
Lasergrbl has a facility to generate cut test files does LaserWeb have a similar facility?
There is no built in ‘test file’ system in LW, I guess you are talking about ‘speed/power’ test grids etc… It’s a nifty feature but LW has no provision for it.
LW does, however, allow you to save the entire workspace (eg image and cut data) as a .json file. This means that once you have a test file you can save / reload it when needed in a ‘machine / gcode neutral’ format, and even share that between machines.
For an example see this:
It still seems to work :slight_smile:
You can also ‘roll your own’, see the following older discussions:
Thanks for the info.
I think I will use Lazergrbl for now then see if I can make my own up
