hi everyone! i recently bought a blue laser of 40w 450nm, i am using a 6+ glasses, but and my partner is using the 4+ glasses, i have thinking of using the machine a lot, so i want to have a super secure system, i make a enclosed system for my laser machine, i want to put a panel in top of the enclosed system so i can monitoraded the machine, off course even with this panel i will still use my glasses, i have two options in mind, one is the “Acrylic Sheet - Class 4 Viewing - 410”, that specs are: “410 is an Acrylic laser filter window offering protection primarily from 190-532 nm and 10,600 nm lasers.” it cost the panel of 12x12 inch $150, and the second option if the “Low Power Viewing 920”, that specs are protects from certain laser wavelengths and proves a maximum optical density of 4+. This laser safety windows offers protection primarily from Class 2 and Class 3 laser systems operating between 360-610 nm. , this one cost $55 the 12x12 panel, so i want to buy that one, but i don’t know if that if good for my laser or i should but the firts that is 3 times more expensive, thanks a lot for your help
It looks like you might have posted about this multiple times? I recommended the discussion of the Engravinator:
Also you might find some relevant tidbits in this thread where I was looking for information specific to far-IR CO2 lasers:
Hi Mcdanlj, sorry i am a bit noob with this post and forums, i believe that my post was hidden (i get a notificaction that my post was hidden due to “spam” i assume that the page do this becouse i put the link to the laser windows ) so i think that nobody can see that post so i created again! thanks for share the information about the engravinator, however i have a doubt with my laser, becouse i was think if my laser if a 4 class or a 3 class, i assume that is a 3 class becouse is a 40w lasser and 450nm, so i was think that the option "Low Power Viewing 920”, that specs are: “protects from certain laser wavelengths and proves a maximum optical density of 4+. This laser safety windows offers protection primarily from Class 2 and Class 3 laser systems operating between 360-610 nm”. i think that should work for my lasser right ? that windows cost 45$ and the option that is made for 4 class laser, cost 145$ i don’t know what you think is the best option, thanks!!
I seriously doubt your laser diode is 40W of optical power. That is likely the input power.
I doubt you are running more than 5-10W of optical power.
i doubt too, for the moment i am using the laser to cut 4mm plywood, and it does good, with one pass.
so i think i can go for the second option ( i still going to use my glasses to even look throught that window )
the second option specs are ““Low Power Viewing 920”, that specs are protects from certain laser wavelengths and proves a maximum optical density of 4+. This laser safety windows offers protection primarily from Class 2 and Class 3 laser systems operating between 360-610 nm”
