Hi Everybody !
I bought a few month ago a Laser Vigotec VG-L7 (20BX) and it’s running perfectly since yesterday…
As information, I’m using Lightburn as software and the generic firmware. And I use this laser only to engrave.
My problem is that in the middle of the job the laser stop.
Each time i’m using the laser i must enable laser mode using $32=1 commands, that’s ok. But, here, when the laser stop in the middle of the job, it’s seems $32 is set back to 0.
Any idea how to keep the $32=1 during the entire job ?
Any idea on how to write this $32=1 in Gcode ?
Maybe (if it’s possible), add this command before each design could be a solution… (I have 8 design to engrave on 8 wood keyring. It stop after 2 or 3 designs)
If no solution, would you have any recommandation on a new laser to buy ?
Thanks a lot for your help !
