Hello everyone,
First of all CONGRATULATIONS to all developers for this awesome software, I love the futures, and easy of use (after wathing a tutorial )
I made a few engraves from an dxf file, came out quite nice, but now I wanted to test a sample raster photo, and the generated code seems to have the S parameter to small, the range is around 0.1 - 0.7. The light on the laser doesnât turn on on such low Power settings.
I pasted a sample code the was generated, with the Min Power set to 50 and Max power set to 100:
G21 ; Set units to mm
G90 ; Absolute positioning
; Pass 0
; First Move
G0 X0.03 Y0.03
; Generated by LaserWeb (lw.raster-to-gcode.js)
; Size : 0 x 0 mm
; PPI : x: 300 - y: 300
; PPM : x: 0.0846666667 - y: 0.0846666667
; Tool diam. : 0.1 mm
; Feed rate : 600 mm/min
; Beam range : 0 to 1
; Beam power : 50 to 100 %
; Options : trimLine, joinPixel, diagonal
G1 F600
G0 X0.03 Y0.03 S0.0000
G1 X0.08 Y-0.02 S0.7575
G0 X0.13 Y0.03 S0.0000
G1 X0.03 Y0.13 S0.7575
G0 Y0.23 S0.0000
G1 X0.23 Y0.03 S0.7575
G0 X0.33 S0.0000
G1 X0.03 Y0.33 S0.7575
G0 Y0.43 S0.0000
G1 X0.43 Y0.03 S0.7575
G0 X0.53 S0.0000
G1 X0.03 Y0.53 S0.7575
G0 Y0.63 S0.0000
G1 X0.08 Y0.58 S0.7595
X0.63 Y0.03 S0.7575
G0 X0.73 S0.0000
G1 X0.18 Y0.58 S0.7575
X0.08 Y0.68 S0.7595
X0.03 Y0.73 S0.7627
G0 Y0.83 S0.0000
On my previous test, where I engraved with Power set to 10, the gcode looked like this:
M4 S0 ; Enable Laser/Spindle (0 power)
; Operation: 0
; Type: Laser Cut
; Paths: 8
; Passes: 1
; Cut rate: 800 mm/min
; Pass 0
; Pass 0 Path 0
G0 X129.00 Y94.00
G1 X10.00 Y94.00 S10.00 F800
; Pass 0 Path 1
G0 X10.00 Y94.00
G1 X9.88 Y94.00 S10.00 F800
G1 X9.75 Y94.00
G1 X9.63 Y93.99
G1 X9.51 Y93.99
G1 X9.39 Y93.98
G1 X9.26 Y93.97
G1 X9.14 Y93.96
G1 X9.02 Y93.95
G1 X8.90 Y93.94
G1 X8.78 Y93.93
G1 X8.65 Y93.91
G1 X8.53 Y93.89
G1 X8.41 Y93.87
Any ideea why the S is so low when I used the Laser Raster setting?
Thank you!
