goodmorning
i m trying to get lasermodule work with co2 psu.
the config is
laser_module_enable true
laser_module_pwm_pin 2.4
laser_module_ttl_pin 25
laser_module_maximum_power 1.0
laser_module_minimum_power 0.0
laser_module_default_power 0.8
laser_module_pwm_period 200
if I use the m1000 fire nnn or off it give me an error like fire is not present. g1 make axis moving without output from 24 and 25. I also tryied to invert both with ! without success. the firmware is the latest also with cnc version. someone had same issue?
