Hello,
I have been successfully running my K40 with RAMPS 1.4 with Arduino.
Recently it appeared to die half way through a print, the laser appeared to dim very quickly and then it just stopped.
I made the assumption that the tube had blown and put a new one in, this fired up very briefly and followed the same symptoms, so i changed the power supply!
I first ran a dry test (laser off) and everything worked fine, head followed correct course and completed cycle, I ran the test with the laser on (started at about 10mA) and after about 10 seconds it did the same again, laser went dim then off and it just froze, repeated same thing and it happened again?
One thing i had noticed when i changed the power supply i could not get the laser to come on, when pressing the onboard button on the power supply it fired but not through the Arduino, I traced the output to pin 6 and noticed this pin never went low to fire the laser,.
I disconnected the Arduino board and just tried to cycle that pin but it just floated at about 2.5v so i assumed the pin had failed, checked the same on pin 5 and it worked fine, so i changed the firing pin to pin 5 on the RAMPS board and it all seemed to work until i ran the test again (also remapped this on the Marlin software )
So now i seem to almost be back to square 1
The tube seems OK and test fires from the board
Power supply seems OK and has correct voltages
I am assuming the PWM is working as the cut is about 10mA, as expected
I am unsure where to go next other than to replace the Arduino Mega board but i dont know what is causing the root problem and what to test next?
So i am exporting models from inkscape using the ‘Turnkey Laser Exporter’ add-in using the format 60[ppm=30,feed=300], 60 was approx 13mA on the current, these were the cut settings for 3mm ply from my previous tube, when i ran at this i was experiencing the problems initially reported.
I dropped the power down to 10 and it ran fine (just marked the wood), now i have increased it to 40 (about 13mA) and it cut straight through!!
Could it be possible that the new tube and power supply are producing a better output than the original but requiring re-calibration?
Regards
Simon
Yes I am up and running, just didn’t expect that much of a power change.
I see what you mean about the pot and will look at reinstating it .
Thanks again for your response
Regards
Simon
