I am having issues with my K40. It starts working 2 seconds later the laser power goes down to nothing.
The pump is flowing and the water temp is fine.
Run through this troubleshooting guide and see what that tells you.
Come back here with the results if that does not help find the problem
When you say is starts working do you mean the laser fires with current showing on the meter?
