So earlier I posted about making a hatch dog to secure the doors on a metal cabinet.
I stacked 2 nuts on the inside to lock them in place so the nut would not work loose as the dog was turned.
When double stacking nuts you typically place a wrench on the bottom nut and one on the top nut to tighten them against each other. In my case the bottom nut was flush against the washer inside the cabinet and it was a tight space. The nuts were only 1/8" thick and none of the appropriate sized crescent wrenches I had were thin enough to just grab the bottom nut. The tight space also meant that I couldn’t try and grab it with the tip of some needle nose pliers.
Then I realized that I had 1/8" plywood and could just quickly laser cut an opened ended wrench. There wasn’t going to be a super amount of torque so the plywood would be fine. Worked great.
