Can you please post a picture of the connector side of your LPS.
Uploading: psu.jpgā¦
I connected mks dlc32 L to spindle minus, so it works at most 15 but, with the mks sbase and skr 1.4 the same, more than 15 but it doesnāt work
Why are we back playing with the controllerās connection to the LPS. We know config 3 works except that the current readings were irrational.
Last you said there was no 5V in that supply when I asked you to measure INās voltage.
The IN pin must have a rational 0-5v signal for the LPS power to be controlled predictably???
I donāt want a graphic of the LPS input connection. I would like a picture of your actual machineās LPS inputs.
I have already put photos of my lps, it does not have 24v and it does not have 5v, this is what you see here
Is that a picture of your actual supply you took or is that a photo you downloaded from somewhere???
That connection diagram shows that it has 5V yet you say yours does notā¦
I AM LOST!
it is a photo downloaded from the internet, but it is the same as my lps, it says 5v but if you measure with the tester they are not 5v, this thing I read on another forum, I tried 3 different controllers and all 3 more than 15 ma not arrives, I managed to get to 20 ma but I wrote that when you move the laser stays on 1 but ruining the work I do
If the supply is not providing 5V it is bad in one way or another.
