Lamina: a free, open-source tool that turns 3D models into laser and CNC cut parts
Hi all,
I made sculptures with Autodesk’s Slicer for Fusion 360 for years. When Autodesk retired it I couldn’t find a free replacement, so I built one. To be clear, I’m the author. It’s free and open source (AGPL), with nothing to buy.
It takes a 3D model (STL, OBJ, 3MF and others) and works out the flat parts to cut and put back together: stacked layers on dowels, interlocking egg crate, radial slices locked by rings, ribs along a curve, or the surface unfolded into papercraft panels. It nests the parts, labels them and exports SVG, DXF, PDF or EPS with cut, score and engrave on separate layers. For routers there’s dog bone relief and kerf compensation.
All the geometry is Python, and it runs in the browser through Pyodide, so nothing gets uploaded. It also runs locally or in Docker. Solo project, built with help from AI.
It’s early days, so there will be bugs. If something comes out wrong, please tell me and help me fix them :slight_smile:
This is a really nice tool! Already played around with it a bit - very cool!
Regarding wishes: it would be nice to able to zoom in and out by modifier keys. Currently the only way is to use the mouse wheel. As I don’t use a mouse (I’m on a Wacom) I need to come up with a workaround, which in my case is using the scroll ring on my Cintiq.
Usually I would hold down Shift or Ctrl to zoom.
Have you tried comparing this to
Looks very promising too! I guess, I know how my Christmas card will be made this year…
