I have a Kossel Mini delta printer from 2016.
I replaced the control board (originally came with a MKS Mini-B 1.0. on of the drivers doesn’t work) with a Panucatt Re-arm/RAMPS 1.4 board with A4988 drivers
I configured the config file from the smoothieware and panucatt instructions, but I get clicking from the steppers and minuscule movement it doesn’t seem to read the endstops.
The config had the default current of 1.5 and I had the ref voltage set at 0.7
It was getting a bit too warm, so I lowered the current to 1.0 and voltage to 0.55 (what it originally came at.
I’m sure that there are a bunch of things to look over, so can someone that has a working Kossel Mini with A4988 drivers and smoothieware working, post their config?
Imported from wikidot
