Jammy
(Julien Morris)
1
This issue is probably caused because I am old, but :
I keep forgetting “Rotarty” is ticked on. Then I start a job and it is ruined.
Would it be possible to indicate somewhere on the main screen that its enabled? Maybe change the text of the “Raster” button to “Raster Rotary”?
Scorch
(Scorch)
2
I will give it some thought.
DuncanC
(Duncan Caine)
3
On my version (v0.54) ‘Use Rotary Settings’ is unticked by default.
Jammy
(Julien Morris)
4
My laser is running on a PI, which I never turn off (along with the water pump).
So with the K40 off, I setup the rotary device, or remove it, then turn on the K40 and log into the PI.
At this point, the rotary setting is what ever it was last.
I know this is local to my setup, but keeping a setting that affects the machine functionality visible seems like a good idea.
