Hello, I am trying to install whisperer on W11but I keep getting driver support installing and requesting $9.99. It is early days for me and I only want to check the K40 board type before spending. Any thoughts please?
That sounds like some kind of scam. It does not cost anything to install and use K40 Whisperer.
Download the installer with this link:
https://www.scorchworks.com/K40whisperer/K40%20Whisperer%20Installer%200.71.exe
Then run the installer with the machine turned on and connected to your computer by the USB cable.
More detailed instructions are here:
To make sure you have a compatible controller board. Look at the board and make sure it is made by LIHUIYU. If you want to you can post a pic of it and I can verify for you.
Scorch
Maybe your used a third party software.
