K40 losing power
it looks like it is arcing around the side of the silver cap , I have taken a closer look and there is a small burn mark where the arc is hitting , so I would agree with you on the issue more than likely being the tube.
looks like I will have to get a new one ordered up.
Thank you very much for your help and I will let you know how it goes when I get the new tube.
Hi Don , just to give you an update , new tube came today and is now fitted.
To say it solved the problem is an understatement , I don’t think the original tube was 100% when the cutter was new , with the new tube the plasma is purple and I can now cut 3mm ply in a single pass @ 30% power, much finer cut and no burning.
Thanks again for your assistance and I hope this post helps anyone with the same issue.
Can you give us some details on what tube you bought and from whom?
HI Don
The make of tube is VEVOR , I purchased in from ebay , this is the listing on ebay
Hello. When you you receive the tube, can you post some pictures with it? I am looking at the tube from the Ebay link and it`s the same brand (KH laser) with my tube who died after around 50 hours of work. Did you get any warranty?
https://forum.makerforums.info/t/k40-internal-mirror-problem/80616
The Tube is already fitted in the machine ( i will try post pictures later)
the seller states 24 month warranty if defective but I guess that would have to be tested as a tube is a consumable item and I would only know if they would warrant it if it fails in that period.
tried to take a picture today but it is not possible to see any details as the label is on the underside of the tube
