Action #2: Unplug the white ribbon cable (the yellow outline) going to the controller.
Does the error still occur when you power up?
What exactly is the error text?
Not being familiar with K series machines, does the ribbon connector have the limit switch lines in it?
If nor, all bets are off because the 8825 drivers do not do stall detect and cannot be homed with it.
And even if that cable does have them, are they connected and configured properly on the board.
If they are present and wired correctly then this may be as simple as inverting the switch polarity in the config.
Yes, the optical sensor switches are in the white flat cable.
I was hoping for a schematic to see how they are connected on the board.
The optical sensors also need to be powered correctly.
I also wondered about the config but figured since this thing is built for a K40 it would have the correct config with it. Best to check.
I was hoping that the same signals that came into the Yellow outline connector also was duplicated at the red outline connector so we should measure the output of the sensor.
Thanks Don
I will post photo as corrected. I have examined the optical switches. The metal tang for each axis passes through and does not touch the sides of the limit switches.
Another problem I am trying to do sort out is the connection of the stepper motors wiring.
The Nema motors have 4 wires. Red, Blue, Green and Black.
Red and blue are a pair.
The FluidNC board for the X axis has a ribbon cable . On the small board where the ribbon cable controlling the X axis is fixed a 4 pin connector is taken off to power the X motor.
The main board for the Y axis also has a 4 pin connector.
The . The problem I have is what order the motor wires have to be connected to the pins,
Unfortunately there is no indication of this on the controller.
I am sorry this is so long winded but I hope this makes sense to you.
Thanks once again.
Thanks. I have now resolved the wiring issue of the stepper motors, got the sequence correct. The little “board” to which the X axis plugs into is the same where the ribbon cable connects. Not sure of the technical name.
I keep getting an error message “Homing cycles not defined” I am trying to get my head around this.
When opening Machine Settings I get the message that it has been read successfully but the page is blank so I cannot check anything there.
I suppose one step at a time.
Lightburn does not know about FluidNC grbl-ish settings so you won’t be able to use Lightburn to change or view the settings. That will have to be done either with the web page of the FluidNC esp32 or via the Lightburn terminal interface.
Lightburn supports only the default GRBL settings and strictly validates to it. I ran into this when I put GRBL-HAL on a cheap diode laser board(STM32 based).
FluidNC provides strong backwards compatibility to the ‘old’ grbl $xx options, but by default doesn’t fully report them in response to $$ queries (you only see the $10 (machine vs workspace position reporting setting), which can confuse lightburn, ugs et al.
The FluidNC documentation is an essential, nee, mandatory read here. There are no compile time options. It is a unified binary. Every setting you need (pin def’s, timings, probing, homing, everything…) is available via the terminal/web console. And a config file is used to load the defaults at boot time.
Unfortunately this is much of a rant but I need to get it off my chest.
FluidNC board with Lightburn.
I have now spent over a month trying to get my K40 working
I keep getting the error “homing Cycles not defined”
I have searched the web for an answer but nothing on this topic.
I have replaced the power pack, the stepper motors, the drivers on the Fluid board as well as the esp32 module.
I have put a request on the FluidNC web page but have received no response
I am now wondering whether it is a board problem or a corruption in Grbl on the board.
Trying to update firmware following the Fluid website in instructions do not work. I input my ip address and Github comes up.
I now think it may be time to ditch this board and install a Monoport controller.
Enough said. Sorry!
It would have indicated that your limit switches were configured correctly or not and if electrically connected correctly or not. Then it would be a matter of enabling the homing cycle settings in the configuration file so that the motors move in the correct direction when the home command is sent( $H ). Remember, the home command is different than the G28 command which is really just a shorter version of G0 X0 Y0 Z0 command. ie G28 goes to zero positions while $H commands it to establish where the zero positions are by moving the axis motors and triggering the limit switches.
FWIW, when installing new boards in 3D printers, laser engravers/cutters, CNCs, etc I’ve found the following a good process:
Recheck your power connections and verify your voltages are as expected(requires a volt meter)
On power up, be prepared to turn your machine off if the motors start to move.
Power up and watch each axis to be sure the movement is towards the axis endstop but power off before an endstop is reached. If not, change homing direction in the firmware or config file.
Power up and manually trigger the X axis endstop and notice if X motor stops moving. If not, recheck wiring of the endstop and recheck configuration of the endstop in firmware or config file.
Do the same for the Y axis after the X axis movement is stopped by manually triggering endstop
Power up and let the machine head trigger the endstops and observe no grinding. Adjust soft-endstops and backing off distances in firmware or configuration file. 2-4mm is often enough.
After a completed homing cycle, test motion of moving the X axis 10 mm( use GUI ) then test moving the Y axis 10 mm. if the distances are not correct, adjust the setps-per-mm setting in the firmware or configuration file for each axis. Retest.
Test the outer limits of your machine by stepping towards the full motion edge of the machine to find your “operating” area. There should be no grinding and every command must result in the expected motion. Note how far you commanded it to go and adjust your firmware or config for that axis max limit. Store these values somewhere so you remember them as you will likely require them in any CAM software to specify your working area.
The motion control system should be mostly configured at this point. Test the spindle operation, or laser operation, or whatever else the machine is supposed to do.
Thanks Doug for your comprehensive reply and advice.
I will try and follow the footsteps outlined and hopefully this is the answer.
I will let you know.
Than thanks. I appreciate your comment and would rather not go to any other board as there must be a way to solve this.
Frustration sometimes gets the better of me.
Some of the links on the Official wiki are broken, the specific page you need is (I think) this: Axes | Wiki.js
Basically, the FluidNC config file has a definition section for each axes where you define the hardware (motor and switch pins), and also define it’s Homing cycle. That page is actually a bit (in my opinion) obtuse but the general idea is that each axis is assigned a homing sequence number (from 1 to 6) and when a full homing cycle is triggered they are homed in sequence from 1 onwards. Two axes can have the same number to home them at the same time. And there are some exceptions for complicated machines with axes that should not be homed etc…
On my FluidNC home CNC I have the Z axis set to sequence 1, then both X and Y set to 2, this means that it first lifts and homes Z, then does both X and Y simultaneously. This is a very common CNC homing sequence to avoid crashing toolbits into the work/clamps.
Edit: It’s really worth scrolling down that page to look look at the examples they give. FluidNC has some really nice homing options.
FluidNC support is done via Discord and having to ask for an invite; something I hate. And then they migrated from GitHub’s wiki to their own http, not https, Wiki, which many browsers will flat out refuse to load.
This is a good for shielding the developers from distracting questions, but not very friendly for those who are getting started.
