The water is INSIDE the outer most tube so you will not find a crack unless you start breaking the tube to examine the inner components. The fact that there is water in the outer most glass casing means the inner tube chamber has been compromised. The tube is no good.
does this help understanding where the water is SUPPOSED to be?
