Hi everyone !
I am new to this forum, please excuse my english, it is not my native langage and i might do some mistakes. I just bought a k40 laser (Chrisun) and i hope that i could find some help. I am running windows 10 and want to install k40 whisperer in order to use .dxf files. I did not try to install the default software provided by the seller, i don’t have an optical player on my pc anyway…!
When i plugged the machine for the first time, it happened that :
- When turning it on, i expected the head to go to home position but the motor keep running and bumping on the limit of the Y axe. The head does not move on the X axe.
- When intalling K40 Whisperer, (by following the setup explanations on scorchworks) the installer can’t even find the machine. The machine is running (i unplugged the Y outpout on the motherboard to avoid bumping, tought i could reset home position directly on the software), the usb cable is connected on a usb slot that works fine with other devices (i tryed with other slots and an other cable, don’t fix the problem). I can’t finish the installation, it says “Cannot install. Laser device not found”. If i close the installation the software run properly, but of course does not operate the machine.
Is it normal that the motor limits are not correctly set by default ?
May i have a problem with the motherboard ? (It’s an M2 NANO)
Did i missed something obvious ?
I will be greatful for your ideas and advices, i’m behind my computer and can provide more info if needed.
Thank you all !
