Just started having a problem with the TInyG - When I run some short Gcode, after several hundred lines or so, everything freezes. I tried this same code in both Chilipeppr and using the Universal GCode Sender. Both were working fine earlier today and both have the same results. Below is the output from the Universal GCode Sender app. Everything is fine up until it says “Move time is NAN”. That is when everything stops. I tired reflashing the firmware using the TinyG updater but the flash failed to verify. Still had the same problem after the flash however. I am able to jog around just fine. Any help or suggestions to try would be much appreciated.
{“r”:{“n”:560},“f”:[1,0,34,6164]}
{“gc”:“N590G1X41.899Y64.252S100”}
[unhandled message] {“qr”:3}
[unhandled message] {“qr”:4}
{“r”:{“n”:570},“f”:[1,0,34,1908]}
{“gc”:“N600G1X42.312Y64.337S100”}
{“r”:{“n”:580},“f”:[1,0,34,4487]}
{“gc”:“N610G1X42.790Y64.403S100”}
[unhandled message] {“er”:{“fb”:440.20,“st”:31,“msg”:“Move time is NAN”}}
[unhandled message] {“er”:{“fb”:440.20,“st”:28,“msg”:“Failed to get planner buffer”}}
