Just ran into this problem as well. Any news on when a fix will be made?
Help!
Originally shared by Dennis Espinosa
Hi Everyone! My chilippepr + tinyg setup just bump into a minor problem. It is working fine projects after projects, actually its working great now, the only problem is when i click the “configure tinyg settings” button i dont get to see the pop up settings bar where i could change some settings. What i get is a “edit in jsfiddle” shortcut bar in which when i click it, it goes to the jsfiddle code or something. I am not familiar with coding and stuff so it puzzles me. I will include some screencaps for you to check. What i need is the pop up settings bar to be back and its all fine.
Thank you.
