Just opened the box should there be a disk? K40
Should, could, maybe, are you lucky?
Find here link with Corellaser and Corel draw if you did not get it https://plus.google.com/114544098138525257938/posts/VKpfwi9KvgQ
Check inside the front & the back where the laser tube is. They suffer all sorts of things in the machine (where it can bounce around the gantry, head & mirrors ) instead of putting a separate pocket in the foam for the accessories.
Sometimes they include a bag that has some things stuffed into it.
Thank you all, I am sure I will need more help and Jim you were correct. I found it in with the blower motor.
