Just in case someone needs a 3d model of the E3D v6 Hotend...
Just in case someone needs a 3d model of the E3D v6 Hotend… you can grab the 1,75mm universal version in a not so detailled version at GrabCAD. Just did a quick drawing this morning as i need it for some mount construction work.
File currently only available in F3D format (Fusion360) and it’s also in their gallery including some more renderings here https://fusion360.autodesk.com/projects/e3d-v6-hotend-1-75mm-universal. You can of course use Fusion360 to export to any format of your choice (it does quite a lot)
Dimensions should be fine but i’ve not yet modeled the fan mount and didn’t do screws, thermistor and heater.
https://grabcad.com/library/e3d-v6-hotend-1-75mm-universal-1
please stl or obj? no want install other software only for convert it …
I’ve added STL and stp/igs. Have fun with it.
Thx!!!
I was starting the same thing last night. Thanks for this. Now I dont have do the block and nozzle :slight_smile:
You can pull the fan shroud stl from e3d’s website.
already got the fan duct. unfortunately it’s STL only
can you assemble stl’s in fusion I’ve just started playing with it in the last week or so.
you can import them but you can’t do much with meshes.
