Just got my K 40 This week Trying to make some Christmas ornaments
But I noticed If I cut Circles Within laser draw The Circles will cut smooth And fast But if I create Something in Ink Scape In use the import Bitmap feature In Laserdrw The cut is sporadic Not smooth at all Any ideas It’s not just circles but anything I import
Thanks
Engrave and cut are two different functions. A quick search on that should help.
The issue you are seeing might be due to low bitmap resolution. Make sure you make a high resolution image from Inkscape. 500 DPI or even 1000 DPI. (Anything over 1000 DPI is a waste.)
