Just got K40
Any chance to update driver to 6C6879-LASER-M2:9 PCB ?
Best Regards
Not sure I follow. If you are going to use the stock corellaser or laserdraw then you will need to set the board type in the software settings.
We actually recommend using K40 whisperer with inkscape for people using the stock control board. https://www.scorchworks.com/K40whisperer/k40whisperer.html
