Just a test, but it works as designed :) Originally shared by Frank Herrmann
Just a test, but it works as designed :slight_smile:
First (extended) XATC process successful.
http://youtu.be/a3ONZNjBsEg?feature=autosharec
Interesting new design. Does the end mill sit in the middle of the gator grip?
@jlauer yes, I designed a 3d printed holder and remove the original plastic center shaft. Then i drill a hole 6mm in this plastic plate that hold the spring loaded shafts.
