OK, I am getting uploads serving correctly. Can someone else now try?
yep seems to be working now
Was that a new image, or one you had tried before?
New image upload
CDN not working?
I wonder if discourseuploadspace.sfo2.cdn.digitaloceanspaces.com
which exists would solve the problem. Want to try that and re-bake?
If you’re going to re-bake use the opportunity to install some plugins.
right now is when rebaking is cheap; I feel like changing one thing at a time is a good thing
We’re at 6:30 to 7:00 minutes for ./launcher rebuild app
to run, and then another 30 seconds after that finishes for the forum to come back online.
Just wait until we import from over 300MB of JSON text files, and see how long rebake takes then!
Since spaces is working as long as I do not enable CDN, I will leave it alone until DO gets back to me on my support ticket. BTW, rebaking posts can be done without rebuilding the app, 1000 posts takes about 30 seconds if you do the following from a root login:
cd /var/discourse
./launcher enter app
rake posts:rebake
I noticed you can also rebuild/rebake individual posts from the admin tools on a post. Just tried it on one of failed image loads above and it worked.
Still working with DO on getting the CDN working. No joy yet.
