John Lauer  John, can u stop chillippr in the middle of a jock to
@jlauer John, can u stop chillippr in the middle of a jock to replace a broken bit, or just to replace tools?
Thanks!
Or I should say “pause” the project.
Yes. If you need to jog then note the last successfully executed line and make that as your start position before you hit play again
@jlauer kool I’ll give it a try :slight_smile: thanks…
