@Jason_Coon 's aurora demos running on my newly built 64x64 matrix. Took very little work to get it working (the code that is, the matrix was a bitch to build, a bit over 4 days of solid work).
Only the ‘Attract’ pattern isn’t looking too good and gets stuck in the middle, ignoring all the pixels around it.
Jason, does it look like a bug, or is it what it does on pixelmatrix too?
@marmil I need to make a blog post on it, but turns out soldering is not even 50% of the work. most of the work was
cutting the cardboard backing to the right size, and marking where the strips were going to go
cutting/fixing all the strips (they were second hand, some were broken or the wrong length)
320 glue points for the strips, one by one
cutting lots of little wires to the right length, stripping them
only then does soldering come in
then test each set of 4 strips (64x4) with a special neopixel tester
build the 10 gauge power bus
the hardest thing has been to solder all the little wires to the 10 gauge power bus turns out. They don’t like staying together.
and all the twisted pair and wiring on both sides (seemed trivial but it was more work than I thought).
Then again, nothing that @Yves_BAZIN does not know
@Marc_MERLIN Ahha but it’s good to share with every body. But I completely agree with you preparing everything cutting wires … it’s long and sometimes painful.
@JP_Roy the animations were shamelessly stolen from @Jason_Coon 's pixelmatrix (although I did have to port from smartmatrix to my FastLED::Neomatrix lib, but it only took a couple of days to get all the demos working once I got the hang of it).
As always, great programmers write great code. Better programmers even, steal
Music is Above and Beyond: https://www.youtube.com/watch?v=CNUTlKqSO-I
