I've never printed with Hilbert curve infill before and I know this will take
I’ve never printed with Hilbert curve infill before and I know this will take ages but it’s an OCD paradise seeing it fill out so meticulously
I’m curious to know: Does anybody use this regularly, is it something you break out on gift prints or did you just not know about it all together?
I’ve always been curious about this too. Never saw a point to the jnfills beyond rect and honeycomb
I would think Hilbert would be the lowest internal stress infill but also the one providing the least internal mechanical strength. In fact, I’m not sure how much better Hilbert would be than “hollow”. I guess it does provide vertical support to the upper layers but almost none to sideways forces?
Honestly, I can’t stand hilbertcurve infills. Puts way too much stress on mechanical components for no reason.
Is there documentation somewhere which compares the different infill using the same material, and maybe stress tests them under compression, tension, side load, and so on at various infill amounts? I just use the linear or honeycomb infills because they seem to work fine, but I’m usually not building high load structural objects. Sounds like a big research project that would need some specialized tools, but it’d be interesting to see graphed results, etc.
