I've just installed LW3, I had previously LW.
I’ve just installed LW3, I had previously LW.
The problem is that the USB connection is never made.
***************TERMINAL ***********************
pi@octopi ~/LaserWeb3 $ node server-smoothie.js
---- LaserWeb Started ----
Access the LaserWeb User Interface:
  1. Open Chrome
  2. Go to : http://127.0.1.1:8000/
  • Updates:
    Remember to check the commit log on
    https://github.com/openhardwarecoza/LaserWeb3/commits/master
    regularly, to know about updates and fixes, and then when ready
    update LaserWeb3 accordingly by running git pull
  • Support:
    If you need help / support, come over to
    https://plus.google.com/communities/115879488566665599508
    WARN: Connecting to Port /dev/ttyACM0,250000
    Connected to /dev/ttyACM0at 250000
    Recv: Smoothie
    Recv: ok
    Recv: Build version: master-47d14aa, Build date: Dec 16 2015 04:10:55, MCU: LPC1769, System Clock: 120MHz
    Recv: Commands:
    Recv: version
    Recv: mem [-v]
    Recv: ls [-s] [folder]
    Recv: cd folder
    Recv: pwd
    Recv: cat file [limit]
    Recv: rm file
    Recv: mv file newfile
    Recv: remount
    Recv: play file [-v]
    Recv: progress - shows progress of current play
    Recv: abort - abort currently playing file
    Recv: reset - reset smoothie
    Recv: dfu - enter dfu boot loader
    Recv: break - break into debugger
    Recv: config-get [<configuration_source>] <configuration_setting>
    Recv: config-set [<configuration_source>] <configuration_setting>
    Recv: get temp [bed|hotend]
    Recv: set_temp bed|hotend 185
    Recv: get pos
    Recv: net
    Recv: load [file] - loads a configuration override file from soecified name or config-override
    Recv: save [file] - saves a configuration override file as specified filename or as config-override
    Recv: upload filename - saves a stream of text to the named file
    Recv: calc_thermistor [-s0] T1,R1,T2,R2,T3,R3 - calculate the Steinhart Hart coefficients for a thermistor
    Recv: thermistors - print out the predefined thermistors
    Recv: md5sum file - prints md5 sum of the given file
    Recv: ok
    Recv: Commands:
    Recv: version
    Recv: mem [-v]
    Recv: cd folder
    Recv: pwd
    Recv: rm file
    Recv: remount
    Recv: get pos
    Recv: net
    Recv: ok
****END TERMINAL
I think it does connect but something else its preventing it to work.
+Peter van der Walt Any ideas on why he is having this issue?
Thats true… just updated to latest edge and everything is OK. thank you
How we can update the software? I have downloaded the program, but, I can not see the milling config part. Sorry if this is dump question.
Sorry, thought you were asking how to update smoothieboard firmware.
