I've finally cracked the Taulman Bridge I had hanging around.
gplus
(Ax Smith-Laffin) #1
I’ve finally cracked the Taulman Bridge I had hanging around. It’s printing really well on hairspray coated glass at 50c and Nozzle at 255. Images below are printed at 30mm/s at 0.28mm height with a 5 loop 3 layer brim.
I’m currently printing out a set of 8mm Nylon Bushings for the FB2020 plus just to sate my curiosity of using Nylon Bushings over standard bearings.
I’m using the 9mm inner diameter model from http://www.thingiverse.com/thing:24990. Due to the nylon shrinkage it works out dead on with no slop on the rods.
(Tom Keidar) #2
would love to hear how they work out, i’m trying to figure out if to try this or get some cheap graphite bushings from aliexpress
(Ax Smith-Laffin) #3
@Tom_Keidar - Im going to drop the XY gantry later and insert them. I’ll update once I’ve run a few prints off.
(Daniel F) #4
what nozzle diameter did you print it with?
(Ax Smith-Laffin) #5
@Daniel_F 0.4 mm. 100% infill. 2 perimeters 0.4 extrusion width
(Griffin Paquette) #6
I’ve been kicking around switching to bushings like this. If I have some extra nylon around I’ll try it
(Aria C Bramanta) #7
My bushing failed (printed with 106taulman nylon), but makes a great housing for igus plastic bearings, still prints using it, I’d go with tribofilament from igus for these bearings
(Ax Smith-Laffin) #8
At almost £70 with shipping for 250g of filament for the Tribo-Filament, I’ll give that a pass.
(Matt Harrington) #9
Ooh, maybe I should print some of these out in bridge.
(Griffin Paquette) #10
I’m trying bridge soon as well. Hopefully they will work well.
