I’ve been using simplify 3d with my Ares & it works like a charm!
If anyone would like the FFF profile i’ll be happy to share.
Maybe you can attach a file to the Ares BBS under Tips. Google+ doesn’t have a file area.
DefaultPLAHigh00.410.480.916.30.20.4480000.20500.2442020030000751050.400270.18501023100999127109992113010Fast HoneycombRectilinear25151005145,-4501040007010.311044500000101152004510001001010010000.1811198198200999900011-110,0|0,0|0,0|0,0|0,0|0,01RepRap (Marlin/Repetier/Sprinter)r22500000G28; Home to top 3 endstops,G29;,M107; Turn fan off for the first layer,; start of purge line,;M320 acceleration enabled for all commands that follow (DISABLED TEMPORARILY),;M201 X850 Y850 Z200 E10000; limit acceleration (ENABLED TEMPORARILY),G1 Z0.8 F6000.000; move to first layer height,G1 X90 Y-90 F10000.000; move to front of build plate,G92 E0; zero the extruded length (for Cura…may not need for S3D),G1 X-90 Y-90 E24 F1000.000; extrude a purge line on the build plate,G4 P2000; wait for ooze to slow,G1 Z0.0 F6000.000; lower nozzle height to bed,G1 X-90; wipe nozzle,G92 E0; zero the extruded length (for Cura…may not need for S3D),G1 Z0.2 F6000.000; move to first layer height,G1 F10000; ensure fast travel to first print move,; end of purge line**M104 S0 ; turn off extruder,M140 S0 ; turn off bed,G28 ; home axes,M84 ; disable motors,M106 S0; turn off cooling fan00Random Song039000.50.80.8600060005000.930.71.4540130000020101103010312-0.5600110000001600.922510011958012208010.333115250.2661100300.24422540
or take this one:
http://dropcanvas.com/#nuzusK50Vspf4M
There you go @Naser_Alj
https://drive.google.com/file/d/0B_sjnvVPcPI0Y1o3cmZTQ25TS1k/view?usp=sharing
that would be gresat if you could upload the ini
or just the s3d profile
the FFF profile is linked above. Download that and import it into s3D
its no longer available would you mind reuploading it when you have a chance
Or upload to Nicolas’ collection https://www.mycloud.ch/s/S00A186C8F537127A037EE1E8649CCCB5EBC875D3EC9FE83402DC508B8F57B6E/ (although @Shmaggy3d_0100001001 you can copy the text and save to a local file without download.)
@Frederik_Van_Melle Would you mind uploading your s3d profile on Yaun’s cloud I would really like to check it out
it’s done
