I've been using fusion 360 to design all the things i make.
I’ve been using fusion 360 to design all the things i make. fusion 360 works great! and there’s even a simulation mode in fusion 360 to make sure everything is good before you run it. but for some reason chilipeppr will end up throwing code in my program that’s not in it, and mess my project up half way through it! it seems to do it often and i don’t know what the hell is going on. Does anyone know what could be causing this to happen? please help me out if you’ve had the same problem and have fixed it! thanks in advance!
First check for a tinyg postproccessor for fusion360. Google it and download then set him in fusion.
ChiliPeppr doesn’t insert any Gcode into your Gcode. The only thing ChiliPeppr does is check if you specified mm or inch and if not it prompts you. It also inserts line numbers. It does comment out %'ages.
Preview your gcode in a text editor.
