I've always had problems printing taulman ThreeD 's Nylon Bridge, until last night.
I’ve always had problems printing @taulman_ThreeD 's Nylon Bridge, until last night. It seems that my Drybox wasn’t working due to the silica being really damp, it’s just standard non colour changing stuff that I’ve salvaged from the multitude of silica packets I’ve got with spools.
Nuked the silica in the microwave in several heat/cool down sessions a day or so ago and left the Bridge in the box until last night. After putting in rod rest due to too much drag, I now have pretty damn perfect nylon bushings.
Also as a note, if you have an oven that isn’t that accurate on temperatures, don’t use it to dry your filament. You’ll end up softening the ABS Spool itself…
Two words: Eva Dry.
@Jean-Francois_Talbot - being in the UK, it’s not something I can get hold of too easily. And looking at the functionality of it, it’s no different to using Silica in a airtight box and drying it out like I have… If I shoved a moisture card in there it’d be pretty much exactly the same.
Its just for the convenience of it, and the fact you can make them dry by plugging them it.
Making a dry box at the moment as well. I see a huge advantage in the color changing stuff just for that reason.
When I get chips from reputable suppliers, I usually get a little card telling me about exposure to moisture. Maybe you could put one of those on your box. Facing outward, you could see the indication from the outside.
I modded a cheap food dehydrator. I can get up to three spools in mine, and it dries them really well.
@Duncan_Gunn - yeah I have one somewhere but where I have no clue.
@Griffin_Paquette - yeah with the amount of filament I go through it’s a cheaper option, takes a little time to build up but makes the little packets useful…
@Ax_Smith-Laffin I do that with my PLA spools. They’re now in about 50 of those little packets ha.
Wikipedia says one can regenerate Silica gel by in the oven at 120C (250F) for 1 or 2 hours.
I just talked to my local pharmacist two days ago and asked if their shipments included desiccant. The answer is yes, and they are now putting a bunch aside for me.
@allanGEE - win
Gotta remember that silica shipping packets are typically pretty well saturated by the time you get them. (A thin plastic bag just slows down moisture, it doesn’t stop it.)
Nylon loves water so much it will actually pull water out of silica unless the silica is bone-dry. I recommend oven-drying and then using calcium chloride (eg Damp-Rid) since it’s more aggressive at moisture absorption than silica.
Also, make sure to make your drybox out of polypropylene, not something permeable to water like polystyrene…
@Carlton_Dodd that’s a brilliant idea!
In France I bought this one https://www.amazon.fr/gp/product/B004AM2TB2 which recharges by plugging it and it’s awesome!
@Derrick_Whittet_Wint
I just got a cheap one from Amazon, and made a quick extension with cardboard (I intend to make a Plexiglass one at some point).
Google Photos
I buy silica gel (called "heated sand " and made in China ) kitty litter from the supermarket. Two kg for a few dollars.
@taulman_ThreeD had plans on their site to build a dehumidifier. Works great. http://taulman3d.com/drying-materials.html
