It would seem that my aged Azteeg X5 board has died.
It would seem that my aged Azteeg X5 board has died. fuse blew and now (after replacing fuse) it won’t heat bed or hotend. USB disconnects when i try. If it needs replacing, what controller would the community recommend for a mendel90-derivative 3d printer?
I would use the Cohesion3D mini or remix boards.
for a cartesian a plain old ramps is good enough. just add fancy drivers and you are good to go.
C3D all the way. Ray has great support if you have an issue. His boards are well made.
it would seem the wisdom of the crowd is clear. Cohesion3d it is.
