It seems to me that speed/acceleration of small circle compared to speed of long
It seems to me that speed/acceleration of small circle compared to speed of long lines is faster… ??
Our CNC is built out of wood so the head is prone to have a bit of play.
Doing small circle cuts like cutting holes I can see clearly the head moving in its play while doing long cuts it seems like it is not having that play…
Is is possible to fix this ? Maybe decreasing the overall acceleration?
Simone
ChiliPeppr doesn’t do acceleration. Your firmware on your CNC controller does that, so you’d have to defer to those docs to tweak.
sure what I meant was to change gbrl acceleration
Note that some CNC firmware actually supports a circle command.
