Issues Printing Horse STL Model – Layer Shifting and Detail Loss
Hello everyone,
I am currently trying to print this Elegance Horse STL model:
https://corb3d.com/model/elegance-horse-stl-file-3d-printable-luxury-home-decor/
The model looks very detailed and well designed, but I am facing some issues during printing. The main problem is with layer shifting and loss of detail, especially around the legs and head area. I am using an FDM printer with PLA filament, 0.2 mm layer height and supports enabled. I have tried adjusting print speed and temperature, but the issue still appears. Has anyone printed this model before or have suggestions to improve print quality and stability? Any help would be appreciated. Thank you.
Have you first tried using the recommendations of the designer? .2mm layers is not what’s recommended for detail so what else are you skipping?
Shifting layers is a machine problem. What FDM machine are you using and maybe post the 3mf file from your slicer so we can see what you’re setting.
