Hi everyone
i’m new to smoothie and recently buy one for a glue dispensing CNC project. in this project i need to control 3 penu-valves for gluing operation.Valve No.1: inject , Valve No.2: Help Valve No.1 to suck air behind glue quickly to prevent pour extra glue, Valve No.3: used to uplift and lower the glue syringe pump. Here is the question. in this case i’v used 4 “misc” module in “config” file of smoothie but when i call them in a G Code, only one of them works. others remain off and i don’t know why. but when i use another module (like “fan” for example) it works perfect. why i can’t use multiple “misc” modules in smoothie board V1.0 “config” file and call them separately? (Firmware: CNC-latest , Board Version: v1.0a)
Here is my config for MISC
switch.misc.enable true #
switch.misc.input_on_command M40 #
switch.misc.input_off_command M41 #
switch.misc.output_pin 2.4 #
switch.misc.output_type digital # just an on or off pin
switch.misc.input_on_command M42 #
switch.misc.input_off_command M43 #
switch.misc.output_pin 2.5 #
#switch.misc.enable true #
#switch.misc.input_on_command M44 #
#switch.misc.input_off_command M45 #
#switch.misc.output_pin 2.6 #
#switch.misc.output_type digital # just an on or off pin
#switch.misc.input_on_command M46 #
#switch.misc.input_off_command M47 #
#switch.misc.output_pin 2.7 #
Best Regards.
