Is there anyway of doing a grey scale photo with laser draw or is just the amound of dots in the picture. I’m new to this stuff so sorry if I sound vague. I only have the Cheap chineese 40w
I have the same cutter but am not experienced with it yet. I read in this tutorial that JPG works best for greyscale : http://www.daycounter.com/Articles/LaserDrw/LaserDrw-Tutorial.phtml
Hey Tony. If you take the image, grayscale it, then dither @ 60% you can produce a decent result. You may need to tweak brightness/contrast (else dark areas may come out too dark). Check this one I did using method suggested by Marc G.
https://plus.google.com/+YuusufSallahuddinYSCreations/posts/AJCXBuJffLt
(hoping this is what you are meaning)
That looks good Thanks will give it a try over the weekend
