Is there any way to speed up jogging on my K 40?
I’m running LW4 4.0.988 with a Mini C3D board. When I use live jogging or go to xy zero and when I start a job the laser head moves very slow. Am I missing a command in Inkscape or LW4?
@bbowley2 ​ under Control TAB there is a X/Y Jog field Bellow the arrows. Have you increased that speed?
It defaults to X Y 1000 mm/min. that sounds too fast but the machine is very slow. Early on the jog was fast. don’t know what I did to slow it down.
That’s 10 not 1000.
10 is extremely slow. Are you in mm/min or mm/s? In any case try 3000mm/min
