Is there any way to make the laser head move across the whole vector
Is there any way to make the laser head move across the whole vector instead of just moving over the filled path while using operation “laser fill” path? I find that small filled paths create lots of jerky motions at higher engraving speeds. I usually have to slow it down more with small vector designs that have filled paths. Thanks!!
I’m sure @Todd_Fleming ​ has the technical answer on why it is this way
You could do multiple inset operations, or change angle of the fill path to be in sync with the most of your path.
Speed. If you want it to scan like a bitmap then the easiest way right now is to convert to bitmap.
Ok thanks for the insight! I guess converting to bitmap makes sense. I’ll give that a try.
@Todd_Fleming Thanks for the bitmap suggestion. I gave it a shot and here is the result. You can really tell the difference in the stars
