Is there any documentation on how to create my own workspace? I’d like to get rid of the visualizer since I’m only doing rotary work (custom machine with X, Z, and A axis only) and it’s just a waste of space since it doesn’t visualize the rotary code properly. I just checked the tinygtablet workspace this morning, but it appears to be an older version of the interface, and things like the touchplate widget aren’t entirely visible. I’m sure I could hack something together if someone could point me in the right direction to get started. Thanks!
There’s a great video on the homepage towards the bottom that shows how to create your own workspace. It’s really easy.
Awesome. Thanks! I’ll give it a shot.
You can check out http://chilipeppr.com/darkness. Theres a tablet mode button in the widget menu. You just hide the 3D viewer and change a class on each side column div. Code is at https://github.com/voodoomm/workspace-tinyg-darkness.
@Andrew_Powell Nice. Thanks!
