Is there a way to let simplify3d generate gcode in relative positioning instead of absolute positioning? I am not talking about switching manually between G90/G91 inbetween the generated gcode via scripts. I want the generated gcode be relative from the start.
If there is, I can’t seem to find it. There’s relative E, but not relative motion.
I didn’t find it either…
Probably not, but writing a post-processing script to convert it should be relatively straightforward…
