Is there a way to change default values in ChiliPeppr short of forking the
Is there a way to change default values in ChiliPeppr short of forking the workspace? I’m interested in setting the height of my touch plate so I don’t have to do it manually every time.
What workspace are you using? I believe the TinyG workspace remembers the setting.
I’m using the grbl worksoace
You’d have to fork that widget then and tweak it to store the settings the way the TinyG widget does. Jarrett Luft initially created that version of the widget to work for Grbl off of my original widget for TinyG, but perhaps he left that part out or I added it later to TinyG and he never added it. @raykholo made a new version of the Grbl workspace that we will soon promote to the main workspace so I’m sure he’d love to get a new version of the Touch Plate widget in there if you are able to tweak it.
You should probably check out /grblStaging because it may have a cloud9/github version of the touch plate widget in it which you might find easier to fork than the JSFiddle version.
