is there a Single or Dual hotend carriage for either the herculien or eusthanios
is there a Single or Dual hotend carriage for either the herculien or eusthanios and variants that have a spot for a barreltypes/threaded probe? specifically this or similar size
i have looked and cant find one.
@Eclsnowman @Zane_Baird
tagged incase some are found so they can be archived.
@Zane_Baird ​ you have that new Carriage with the probe you would be willing to share?
Otherwise I know @Markus_Granberg ​ has his direct drive version.
long as they fit the bushings used in the herc BOM i aint picky :stuck_out_tongue:
you can always get blender and add one to the .stl, it’s great to learn the basics of modeling and printing 3D objects.
I have been trying to learn solid works and others.
Not at that level quite yet
https://drive.google.com/open?id=0B7kgdYk7GVumcFFOMV9SZlRoeGs
Thats my carriage. Its for igus bearings tho…
they look pretty close to the 7z41mpsb10m https://www.sdp-si.com/D795/HTML/79501077.html i use. is it just a different material these igus are made of?
Yes the igus bearings is made of their plastic blend. Super light and easy to get hold of where I live.
ok. but the external dimensions should be the same no?
Do you have the STL you printed from? i cant navigate the STEP File effectively. :frowning:
Google Photos
talking about the devil, my order just showed up…
Sure I save a stl file for you, but i dont think your bearings will fit without modification, but its close!
https://drive.google.com/file/d/0B7kgdYk7GVumZmQ5LTE0MlJSU1U/view?usp=sharing
https://drive.google.com/file/d/0B7kgdYk7GVumOVVuclFNTjJMYTQ/view?usp=sharing
https://drive.google.com/open?id=0B7kgdYk7GVumZmQ5LTE0MlJSU1U
oh wow. those are alot thinner than i thought they would be. hmm…guess its back to the drawing board :frowning:
thanks for trying @Markus_Granberg i do appreciate it
@Jim_Stone I have a carriage that includes a location for a probe, but it is for different bearings. I recently modified the carriage to fit the bushings in the BOM, but also removed the probe point. I’ll look at it and see if I can easily include the probe again.
thank you @Zane_Baird !!! :smiley:
@Jim_Stone I don’t have time to make the modification necessary at the moment, but I have a working version that doesn’t include a spot for a probe. I plan on making a commit to the github after MRRF that will include solidworks and .stl files for different derivations I’ve made
Ok. Maybe with normal solid works files I could figure something out. Or fail horribly haha. Either way. I can guarantee it will be chunky and ugly…and probably a cube with a hole that is 2 piece n tightens lololol
welp this sucks. the computer i design on psu died and took everything with it. and the laptop i run the printers and flash firmware with isnt powerful enough to 3d model so i cant do my bad designs even if i got my paws on something to muck up :frowning:
@Zane_Baird whats the status on your end?
Try onshape it runs in your browser or phone/tablet. And it’s free
