Is their any controller available to drive huge amount of Addressable led(Ws2811) over Artnet Or e1.31
As per my knowledge Some is like
◆ Espixelstick (Drive upto 5 Universe over serial data)
◆ BC216 (drive upto 16 x 300 = 4800 Chennel /512 = 9.38 Universe + 2 dmx Universe output)
◆ Falcon F16 Series ( Same as BC216)
◆ Esp32(using Fastled 16 parallel output)
◆ T8000(works only with led edit software 8 x 1024 Led pixel will drive)
◆ T300k(recorded data in sd card & live screen sharing 8 x 1024 led pixel)
◆ Pixel Blaster(https://t.co/MPmGvU0FpV?amp=1)
Please share your suggestions
Any controller will ok, that gives parallel or singel serial line output
@kamal_sonani I am using an esp32 (part of your list) and control 6000 leds via artnet.
I think the esp32 could go to 12000 leds but then you run into memory issue.
Or you need several board which are synchronised.
In the professional realm you could take a look at the MADRIX nebula or the enttec pixelator for a standalone controller. If DIY, I would agree with Yves on the Esp and parallel.
